aztortuga's avatar
aztortuga
Tucson / residential refrigerator
Can anyone recommend a source in Tucson or near tucson that can install a residential refrigerator to replace a norcold 1200. Looking for those who have had it done and appreciate the new install. My Norcold is on its last legs so plan to replace with a residential.
  • Premier coach in Tucson has done a good deal of work for us. It's a small, well run operation and they can do most anything from a small repair to a full remodel. The fridge should be an easy project for them.
    http://www.premiermcs.com/
  • Sorry, but, after buying my new motorhome from Freedom RV, I wouldn't let them check the air in my tires... I would go anywhere else, in fact we do. Spend ~8 months a year in Benson, just down the road, and I have all my work done at Lazy Days in Tucson. They've always done a superb job and their prices are reasonable, at least as reasonable as labor costs go on motorhomes.
  • Thanks to those who replied. Will contact both recommendations for information.
  • Can also recommend Ken Cameron in Tucson area. Not sure he is set up to do fridge swaps but he is certainly qualified and competent. If he can't do it he can probably recommend someone who can.
  • Ivylog's avatar
    Ivylog
    Explorer III
    Here is my DIY Install of a 21 cuft that almost fit perfectly...1/2" to high instead of the usual 6" BUT it is not a counter depth unit so I had to take out the driver's window to get it in. If the DW is short and you do not mount close to the floor it may not be for you.
    Many us the 18 cuft Samsung as it's a French door, counter depth and will run on a MSW inverter. We dry camp often and with two more batteries it does great. My mistake was not doing this sooner.
  • Freedom RV can do it. I've never had it done but seen others that have. I had them change out TV's including cabinet modifications etc. Great work, not cheap though. Another possible source is Cameron RV. He's an independent tech highly regarded by many, but I do not know anything about him and the job you have in mind.Cameron's pH is (520)490-7632
