TelemanExplorerJul 18, 2020Turn signals, brake lights blow fuses ONLY when motor is onThey work fine with ignition switched on but motor off. 88 Coachmen,P30,454.Voltage regulator? If so where is it located? If not any ideas?
enblethenNomadJul 18, 2020Voltage regulator is internal to the alternator.Check voltage output from the alternator.
Related ContentTowing lights issueBrake light/ turn signalReplacement Lights for TTRear Lights ( Brake,Signal & Running)Brake/turn signal lights don't work, running lights do
