DrewE
Mar 08, 2017Explorer III
donn0128 wrote:
Check your lights first. Second, check the turn signal switch. Flashers are generally mounted to the under dash fuse panel.
Since it was posted the four way flashers work, the lights are okay (and I would guess the flasher as well, assuming it's probably the same flasher unit for both functions). The turn signal switch would be my primary suspect in this case.
