golfknut's avatar
golfknut
Turn signals
On our way to Florida from Michigan and just before we got off the highway for the day our turn signals quit working on our 2005 Ford E450 chassis motorhome. We are towing our car. Haven't checked the car's
Turn signals yet to see if they work.
When set up for towing separate bulbs were installed in the toad and wiring from moho was run to the turn signal bulbs to operate them.
I replaced the 10 amp fuse under the moho dash but it didn't fix it.
Any ideas?
I see there is a higher amp fuse in the fuse box in the engine compartment and one fuse spot is labeled "towing turn signals". Could that possibly be it?
  • "towing turn signal" fuse is for the trailer connector on the rear of the MH.
    You should not be tapping the MH tailights for the toad.
    You could be overloading the light system on the MH. Possible the lamp outage module is toast if equipped.
