Hank_MI
Jun 14, 2015Explorer
TV enclosure ? -Solved
'03 Winnebago Adventurer. Would like to replace the front 25" analog TV. Not sure how to remove the plastic enclosure. The front portion has plastic clips/inserts/caps that appear to hold it to the rear section. Don't want to break them trying to remove them so I can separate the 2 pieces. I tried, gently, to pry them off with a knife but that didn't look like it was going to work.
If anyone has experience with this type enclosure I sure would appreciate your help.
Okay, the clips/inserts/caps are only for the rear portion of the enclosure. The front portion is held on by 2 screws inside the cabinets on each side. I'll have to remove the TV to see how the rear portion is held on but at least it's a start.
