2006 Gulf Stream Yellowstone 36. I cannot find what the problem is with the front TV on the coach. Rear TV works great but front TV seem to not be hooked up the RV antenna. Oddly, one channel works ...
Okay....I reread your post several times. It says you connected the cable form the antenna to the DirecTv box and then from the DirecTv box to the TV???? If this is true, you'll never get your front TV to work. The rear one probably has a better tuner and since you get local stations with the antenna down, it's picking them up without the antenna.
The antenna needs output needs to go to the BOMB and then both TV's....or from the antenna to a splitter and both TV's.
