texasredeye
Jan 15, 2015Explorer
TV trouble
2006 Gulf Stream Yellowstone 36. I cannot find what the problem is with the front TV on the coach. Rear TV works great but front TV seem to not be hooked up the RV antenna. Oddly, one channel works ...
wa8yxm wrote:texasredeye wrote:
Wall plate has 12vdc female receptacle and ant coax male connector.. No lights and no switches. What is 12vdc receptacle for?
Considering the size of the fuse and wire feeding that plate,, That,,, is a very good question.
I would suggest a LED map light (The plug in to dash outlet type) to illuminate the area when connecting or disconnecting the coax.. About all the power it has to spare (one or two LED's).
