Ponder wrote:
Thanks Bob B for that........
Do you have an equally straight forward way to run both AC units from the generator. (no shore power) The coach has a switch that selects either AC unit but not both?? Thanks..
Ponder
Yes,, Set the Front/Rear switch to Front.
The automatic transfer switch in the coach should then Transfer the rear air conditioner to the 20 amp lead on the generator.
(This assumes a motor home, installed generator and automatic transfer switch)
You may also have to turn the 20 amp breaker on the generator itself back on.
