Oldme wrote:
The OP said "I'm looking at a new car, but it can't be towed 4 wheels down".
That limits the OP to a dolly.
I see a lot of comments against his only option, by people that do not use a tow dolly. I fail to understand why.
We have had an Acme EZ dolly for 3+ years now.
All welded construction and American made.
Built in Surge Disk Breaks and LED lights.
There is NOTHING else to buy or install.
Tongue weight is under 50 lbs.
Total Weight is under 400 lbs and at age 67+ I can easily roll it around.
Setup is around 10 min and we are off and running.
I took reflective tape and marked where the ramp center need to be so
when I setup they are ready.
The unit tracks well and I have to remember to check that it is there.
Simple, easy and effective.
We are pleased with it.
Old me. I just purchased a used master pro dolly so haven't had the opertunity to use it yet. You mentioned you used reflective tape and marked where ramp center need to be. I am not sure what you are talking about. Can you explain so a dummy can understand?
Thanks!
