kcgaz
Jul 09, 2017Explorer
Two Questions
We live in Arizona where we have had extreme heat over the last week with more hot weather to come. First Question - I know that I need to run my generator under a load every month or so, but my ri...
Passin Thru wrote:Interesting.....I heard it was to dry any condensation off the armature that can cause corrosion and that the crankcase issue was a myth. I guess we all grab onto to what we want to believe.
Actually, the reason for running or exercising your generator is to burn the moisture out of the crankcase. run it til it gets hot and then 10 min more thus you will boil condensation out of the crankcase and pistons. That's the reason for every 30 days and you get condensation in Yuma where it's 119 every day. I am a aircraft mechanic so let the others do their's their way.
