tatest
Apr 25, 2015Explorer II
A 300 HP B-series Cummins is not "typical" of DPs iit is minimal. A Freightliner 26,000 pound chassis with a B-series will usually be rated to tow 5000 pounds. That's what you'll have on a diesel Bounder or many other entry level DPs.
What is typical for diesel pushers is a powertrain rated for 50-100% more torque, a heavier Allison transmission, and a tow rating of 8,000 to 10,000 pounds, or at least that much difference between GVWR and GCWR.
Some entry model DP lines would have an engine/transmission upgrade option to get more chassis capacity (usually to a 7 liter Cat or a MBE) but Fleetwood did not do this with the diesel Bounder.
Actually, while A gassers are usually rated at 3500-5000 based on the hitch installed, the smallest motorhomes on Ford's F-53 chassis might have more than 10,000 pounds towing capacity, because all chassis from 14,700 to 22,000 GVWR shared a 26,000 GCWR.
