Chum_lee
May 16, 2018Explorer
Harvard wrote:
This is just a theory:
When the pressure in a tyre is reduced the contact patch is enlarged. The total dynamics of the rolling tyre start where the “rubber hits the road”. As such one half of the increase in the contact patch length is added to the mechanical trail there by increasing the straight line stability in the same manner as increasing the caster angle.
(Mechanical Trail is the moment arm between the steering pivot point (fore) and the center of the contact patch (aft))
"Dynamics" is the key word. When a tire is improperly inflated, the loads on the contact area change excessively causing unwanted scrubbing wear. That can show up as cupping wear as previously mentioned. It can also cause excessive linear wear on the outer edges of the contact area or any combination of other wear issues depending on how low the pressure is. Low tire pressure causes the inner portion of the tread (center) to carry less load than the outer portion of the tread. Tire wear is a very complex issue. I suggest you contact the engineers at Goodyear, Michelin, or any other major tire manufacturer if you want to learn more about it.
Or join and post your theories at www.eng-tips.com in the Automotive Engineers section. (no affiliation)
Chum lee
38,773 PostsLatest Activity: Apr 25, 2026
