maillemaker wrote:
Also, are you *sure* you have a leak and not a drain valve that was not fully closed?
If you have a leak and you turn on your water pump it will not shut down, or it will keep coming on intermittently as the pressure in the system drops. Obviously you will have to disconnect from city water to find this out.
Steve
I haven't learned yet how to turn on the water pump. I'm not even sure if the water tank has water in it. The only thing I did was hookup a hose from my house, put a 40PSI water regulator on it, and connect it to the exterior connector on my RV that reads "City Water".
I'm still learning so much its overwhelming. I know I have water tanks on the thing and I assume you fill it through the "fresh water" connection, and that the pump should automatically work from that if it has water in it, but that's where I'm at.
