zonearc's avatar
zonearc
Uh oh! Sprung a leak!
Had our 87 Leprechaun in the driveway last night connected to the hose (with a regulator on it). All was finefor 8 hours, but iI woke up to find a puddle and water dripping out from around the rear left corner of the RV. I turned off the water but couldn't inspect more because I had to go to work.
Any suggestions on what this could be?
  • Also, are you *sure* you have a leak and not a drain valve that was not fully closed?
    If you have a leak and you turn on your water pump it will not shut down, or it will keep coming on intermittently as the pressure in the system drops. Obviously you will have to disconnect from city water to find this out.
    Steve
  • I think you would be just as well off putting a box fan blowing at the affected area and leaving the doors and windows open.
    The question is, can you *feel* where it's wet, or did the water all go in places you can't blow air into?
    Steve
  • If I rent a dehumidifier from Home Depot, any clue how long it would take to dry out the water? They have one for rent for $40 a day.
  • Sounds like a water line connection came apart and flooded the interior. Better get to it ASAP and dry everything out thoroughly before ply etc., starts delaminating.
