hipower wrote:
As a general point of conversaion it seems that frequenty the lift/transfer pump failures in the 2002/2003 time frame get blamed on seal/gasket material being somewhat less than accomodating of ULSD fuel. I can't say with 100% certainty that this is true, but my 2003 Dutch Star pump failed about a year ago and the shop said they see this happening and the newer pumps have a different seal/gasket material and seem to be lasting better.
As usual opinions will vary.
Yes this is true. The nitrile rubber (Buna N) seals/o-rings were not as compatable with ULSD as the compound currently being used. Also throw into the equation the age of the seals failing. I have not seen any issue with ULSD and seals on new components but that could also be the less age on the components.
Mike.
