down_home
Jan 04, 2017Explorer II
I can't see it. Those plastic tanks swell a lot when full. Could be to support them plus road shield. A large rock, or bolt that will go through a 22.5 in tire will easily penetrate a tank.
at any rate I would fix the rust and reinstall 1/4 in or thicker aluminum plates.
If they are aluminum on steel supports galvanic corrosion/rusting is the reason everything let go.
If they contact the tanks, might want some glue between the two so no movement from vibration etc occurs.
Certainly fix the rusted metal and proper coating to insulate steel from aluminum.
Maybe someone else has a better idea?
38,783 PostsLatest Activity: Sep 22, 2026
