Daveinet
May 05, 2014Explorer
PUCampin wrote:I was thinking along the same lines. A fuel pump or clogged filter will not make the engine crank slowly. If there is a poor connection, the engine heat will aggravate that. 1994 means EFI, so the computer can get confused with a poor ground connection.
Which battery cable did you replace? I had some wierd issues with my car a few months ago with intermittant no crank, slow crank, running ragged. In my case it turned out to be the main ground wire connecting the engine to the battery was loose at the engine. ...
In theory, if it was having trouble getting fuel, that could make it run lean and get hot. A hot engine will crank slowly, but I would assume that your engine temp was normal, so I'm really not suspecting a fuel delivery problem.
38,766 PostsLatest Activity: Jan 10, 2026
