garywg58's avatar
garywg58
Unloaded vehicle weight?
Hello all. We are picking up our 2014 Thor Hurricane 32A next week and have a question about weights. The Certificate of Origin for a Vehicle, from Thor, says the "shipping weight" is 15,522. Is that the Unloaded Vehicle Weight?
The manual says the following:
Unloaded Vehicle Weight (UVW) is the weight of this motor home as
manufactured at the factory with full fuel, engine oil, and coolants.
I don't want to subtract the weight of the full, 6 lbs/gal x 80 gals = 480 lbs. twice in determining the carrying capacity.
I will be lucky in that I can weight it on a scale right after we take delivery, and it will have minimal stuff in it, not including ourselves. So I can see what that weight is, subtract the weights of all the fluids and us, and see how close that is to the above figure.
Thanks.
G Man
  • Also dealer installed options. Your new MH will have a sticker with all those weights listed then you will know what you are working with. The sticker should be in a closet or cupboard maybe with all your paper work. When you weigh, weigh as if ready to hit the road also. You can email us [email protected] and we can send you a copy of our sticker so you know what you are looking for. ENJOY THE NEW MH :)
  • You will need to ask Thor-- it could have several meanings:
    1. They weigh each coach as it goes out the door. With/without fuel, water, etc???
    2. This is a general number for this model. With/without fuel, water, etc???
    3. It could be just an estimate. With/without fuel, water, etc???
    Only Thor can answer your question.
