memtb's avatar
memtb
Unplanned Maintenance
We’ve got an older Class C, which has seen minimal use.....considering age! With our summer travels being minimized this year, we decided to use the motor home for our tri-monthly shopping trip! Figuring that it needs some fresh fuel, and a little exercise for the driveline and the ac.
While in the store, we left the generator running for ac power....leaving the dogs camping out! We returned in about an hour, with the generator “not” running, and the interior getting warm A longer period of time or in an extremely hot region.... this could have been ugly! We have a fairly large project planned for our little class c this summer ( 4 panel solar system) but, generator repairs were “not” on the list!
Once home, and trying to diagnose the problem.....the generator would start, run for a short while, then die! So, I started with the least expensive, easiest to replace and most likely culprit....the fuel filter. Problem Solved!!
This long diatribe is primarily a bit of advice. A very simple thing (fuel filter) could cause you much discomfort and perhaps much worse will on the road. Changing your filter prior to starting your trip could save you some headaches. I recommend having a spare ( cheap, light, small) filter. As much fuel that we go through when on a trip, and never being certain about the quality of every fuel purchase.....a spare filter may save you some heartache!
As many spare parts and tools that we carry ......we didn’t have this little item! memtb
  • x2 and keep the fuel tank above a quarter tank, some units shut off the gen set at a quarter tank.
  • Generally speaking, the longer they sit, the more they fall apart. Run the wheels off it!! Happy travels.
