"I might be over my max tow limit..." Really? I have never seen a Bounder with a 10,000 lb. hitch. In fact, the chassis itself I believe has less than 5000 lb GCWR capacity available. Hope your home grown over weight unit never fails and if it should that you have LOTS of liability insurance. That is, if your insurance company doesn't walk away because you are clearly over stated ratings. You want the Highway Patrol to investigate this other guy? Seriously?
timmac wrote:
weathershak wrote:
Hope you at least left the guy a note.
Well that would have caused a uproar if while attaching the note he opened his door and found the note and saw me, what if he thinks his setup is OK and decided to let me have it..
This is where the highway patrol needs to investigate even though I might even be over my max tow limit, just hope his setup never falls apart at high speeds on the highway..
:D
