sledfisher wrote:
Hi all.i own a 1993 bounder 36 j.i would like to take the small t.v. and up grade them to the newer flats screnns.question is on the front one the cabinates are built around the small t.v. ,I have seen folks that have somekind of metal holder that extends it outside the cabinatewood work. has anyone else done this,if so what bracket did you use.? thanks mic
sledfisher,
The end result of much of what you may desire, depends on how much work you're willing to put in to a job like this. That is, if you want your coach, with its NEW TV, to look like the factory did the job, you need to do a bit of planning BEFORE you even start. I myself am not a fan of pasting a newer LED TV up against the fascia of the cabinetry because it doesn't fit in place. When I did ours, I had to find out how our original Sony boat anchor (103 lbs) TV was actually mounted, what kind of framing was there, how I could modify any and all components to set up, a newer LED style TV.
It's a long, long story but, in essence, the face frame of the cabinetry was held in with small screws from the inside of the adjoining cabinets. Once that was removed, then there was this massive structure that Winnebago installed to make sure that Titanic boat anchor would not fall on our heads as we drove down Americas less than perfect freeways and roads.
I used multiple saws and tools to remove that metal structure. Then, I came up with a mounting system for the new TV so it would fit in the slightly modified face frame of the existing cabinet. Careful measurements were taken and the wood work was done to accommodate the new TV. All said and done, on a 14 year old coach that's fitted with a new, modern LED TV, it looks like Winne did it at the factory. Again, it all depends on what you want it to look like when the job is done and, get the best TV viewing possible at the same time.
Below are pics of my change-over. I devised a mount system that is as solid as a rock. We have no need for viewing at any other angle than straight ahead so, my mount system works flawless for us. And, there's ZERO movement in that TV. And, as you can see, I did the same exact system for the bedroom TV too. It too was an out dated mini-boat anchor. So, I removed it and replaced it with a better LED TV. The wood anchor system is absolutely easy to create and, both the front and rear LED TVs are mounted utilizing the four mounting holes provided in the backside. I'd do it again in a heartbeat.
Scott
