tpcollins
Jun 11, 2015Explorer
Update - generator doesn't continue to run after starting
I brought the RV in today so I could do some more work on the genset. I found the low oil wire, disconnected it and then grounded it, but it would quit when I released the start button. So based on the link that Diplomat posted from Flight Systems, I started going down the trouble shooing list.
I removed the circuit board cover plate, and then removed the 4 screws and mylar cover that protected the soldering on the back side. While playing with it all of a sudden the genet started and continued. I put the cover back on and it would quit, take it off and let it dangle and it ran like a champ (and was putting out 126 volts).
I removed the circuit board entirely and the resister wires were green with corrosion plus the wiring is a bird's nest behind where the circuit board presses up against. I figured there was a short or hairline crack somewhere and the wiring was pushing against the board causing it to short out. I have a replacement board on it's way.
If the new board doesn't work out, I'll just let the cover plate dangle going down the road and hope it doesn't rain! :-)
