Rickieblue
Oct 03, 2015Explorer
The only symptom you may experience if it is sucking enough air, that the vent back to the tank can't handle, is that it will stumble and surge under load and run kind of ratty with no power, and alot of times it will run pretty much normal but when you bring it back to idle it will gallop and stall or just gallop till the air vents out and then will seem fine. Hope this helps..............Rick
38,707 PostsLatest Activity: Mar 03, 2025
