wolfe10
Oct 04, 2015Explorer
With a "hot rubber" smell, check your belts. Suspect you have a serpentine belt and a separate V belt driving just the water pump.
Particularly if one of the accessories (A/C compressor, alternator, fan hub) are starting to seize up, they will cause the belt to slip and burn.
Also, if the separate water pump belt is loose, it can cause this-- it is on a manual, not automatic tensioner.
Bottom line, with a burned rubber smell, I would not drive until diagnosing it.
38,707 PostsLatest Activity: Feb 28, 2025
