JackMS
Apr 15, 2019Explorer
If your separator is the type with the clear glass on top, there is usually an anti backflow valve in the outlet fitting. Very simple construction- a plastic cage with a ball and spring in it. Any bit of trash can cause a long crank situation, but it takes a while after shutting down to show up. If your engine is running and you shut it down and immediately restart, does it start better? If so then probably not that check valve.
