scroller95969
Sep 01, 2013Explorer
Thanks for the update. I'm glad you found the answer for your overheating. Unfortunately for me I have already replaced those 3 items including using a Hayden severe duty fan clutch. I did however use the 187 degree thermostat instead of the 180 degree that you used. Maybe I should install another Hayden fan clutch, radiator cap and thermostat just in case the slight chance that I might have gotten a defective one. My problem sounds slightly different however because I can hear my fan clutch turn on about 224-235 degrees. Thanks again, Jeff.
38,782 PostsLatest Activity: Sep 10, 2026
