NTORACN
Sep 02, 2013Explorer
scroller95969 wrote:
Thanks for the update. I'm glad you found the answer for your overheating. Unfortunately for me I have already replaced those 3 items including using a Hayden severe duty fan clutch. I did however use the 187 degree thermostat instead of the 180 degree that you used. Maybe I should install another Hayden fan clutch, radiator cap and thermostat just in case the slight chance that I might have gotten a defective one. My problem sounds slightly different however because I can hear my fan clutch turn on about 224-235 degrees. Thanks again, Jeff.
oh yeah, does your fan clutch roar for the first 30-60 seconds afer a cold start? If not, the fan clutch is NOT working properly and needs replaced. the thermostat can be tested in your kitchen using a small pot of boiling water and an oven thermometer. Take your radiator cap to your regular mechanic to be tested. That way you don't replace good parts with good parts.
38,782 PostsLatest Activity: Sep 10, 2026
