IAMICHABOD
Sep 13, 2014Explorer III
A bit of update on my overheating problem. Just like NTORACN the only time that it overheated is on long pulls.I am not towing anything like NTORACN and scroller95969. But this test was done with it ready to camp with full fuel,water and food.
I had the Hayden # 2786 Severe Duty Fan Clutch installed and it seems that it has done the job.
I then ran a test on the same grade as the one that I had a problem with before when the temp went to 237. This time it kept the temp to about 215 then cooled down to 206. I then tried it again with the Tow/Haul on. Both times it was at full throttle. With the outside temp at 96.
With the Tow/Haul on the RPM was higher and the shift points changed and the temp hovered between 206-208.
So the new fan clutch worked and I will now use the Tow/Haul more.
Forgot to add ......Dash A/C on, running on high, man that thing gets cold!
Thanks Randy!
Thanks Randy!
38,782 PostsLatest Activity: Sep 10, 2026
