ScottG
Feb 12, 2014Nomad
Desertcat921 wrote:
The problem here is that not all parks are 240 VAC for 50 amps some just use 120 paralleled to both hot legs so neutral carries the whole sum of the two legs. This means if the neutral is smaller and you are using heavily you may have an overheated wire ....Jerry
Then this would be in direct violation of the NEC and should be reported.
This is not a normal or common condition.
And a balanced load would be the least of your problems.
Come on guys, lets not delve into obscure what-if's to try and prove what is in every way technically wrong.
38,780 PostsLatest Activity: Nov 24, 2017
