RoyB
Apr 09, 2016Explorer III
Don't confuse the converter/charger unit with the 120VAC -12VDC Power Distribution Panel.
Most of the time the Converter/charger sits in the bottom compartment of the Power Distribution Center and all you have to do is just replace the 120VAC wires going to the Converter/charger unit and the two or three wires associated with the 12VDC output cables.
Hopefully you won't have to replace the Power Distribution part where the Circuit breakers and ATC fuses are located..
This is a WFCO Power Distribution Center with things removed showing this... The bottom compartment is where the converter/charger unit is located...
NOTE this is generally how the RV Trailers are setup. The MOTORHOME type units are a bit different as they may come with an installed POWER INVERTER where this is most often an option item for the trailer folks... The POWER CONVERTER/CHARGER and the POWER INVERTER are two different animals
Roy Ken
Roy Ken
38,782 PostsLatest Activity: Aug 11, 2021
