Bobbo
May 04, 2013Explorer III
The Trik-L-Start doesn't use 110v, it only uses the 12v system. I went to the relay that connects the batteries together in an emergency. I put the input wire on the side of it that is connected to the house battery/converter, the output wire on the side connected to the chassis battery, and the ground wire to the body of the relay since it is grounded to the frame. It just bypasses the relay. The Trik-L-Start has a diode in it to prevent power being transmitted the wrong direction, and will provide 5 amps to the chassis battery anytime either the house battery is turned on, or the converter is supplying power.
38,769 PostsLatest Activity: Apr 04, 2026
