tropical36
Dec 08, 2016Explorer
TT_Tim wrote:
I'm thinking of moving up to a coach from our 5th wheel. After researching, I've compiled the following.
2013-2017 Diesel Pusher
33-39' length
Must Haves:
OCCC 3500 lbs. with additional
tow capacity 6000 lbs.
Nice Haves:
King Bed
Fireplace
Washer/Dryer
Models interested in:
Tiffin Allegro Red 37PA
Thor Tuscany 36MQ
Holiday Rambler Endeavor 38K
The issue I am having is that most manufactures sites do not show the OCCC, dry or curb weight. Only the GVWR and GCWR. I realize it varies depending on options, but is there another way to determine the capabilities? It appears the Allison 2500 transmission limits GCWR to 33000 lbs. Any other model suggestions similar to the three I listed?
Thanks
You'll be wanting to go look at them anyway and all this is posted in a closet somewhere.
As for CCC, even though more than adequate, keep in mind that it might not be distributed evenly over both the front and rear axles and they don't tell you that, so you still might have to be careful loading.
38,769 PostsLatest Activity: Apr 04, 2026
