luvlabs
Dec 08, 2016Explorer
If you like Tiffins, the 2017 models now have the larger engine and transmission. Tow rating is now 10,000 pounds. The 2500MH Allison was the reason for the 5,000 lb tow rating.
The CCC will vary by coach is it is based on the weight as built, the GVWR of the chassis and certain estimates - 1) full water tank; 2) full propane tank; 3) full fuel tank; and 4) 4 passengers @ 150 lbs ea. What is left is CCC. You need more CCC - carry less water, fewer passengers, etc. You can easily pick up 1000 lbs of capacity if you need it.
Tiffin posts all this information in the bedroom closet if you are looking at coaches. The other manufacturers you mentioned will post them someplace in the coach so just look.
38,769 PostsLatest Activity: Apr 04, 2026
