rk911
Dec 08, 2016Explorer
TT_Tim wrote:
I'm thinking of moving up to a coach from our 5th wheel. After researching, I've compiled the following.
2013-2017 Diesel Pusher
33-39' length
Must Haves:
OCCC 3500 lbs. with additional
tow capacity 6000 lbs.
Nice Haves:
King Bed
Fireplace
Washer/Dryer
Models interested in:
Tiffin Allegro Red 37PA
Thor Tuscany 36MQ
Holiday Rambler Endeavor 38K
The issue I am having is that most manufactures sites do not show the OCCC, dry or curb weight. Only the GVWR and GCWR. I realize it varies depending on options, but is there another way to determine the capabilities? It appears the Allison 2500 transmission limits GCWR to 33000 lbs. Any other model suggestions similar to the three I listed?
Thanks
try calling the mfg. if you give them the VIN the mfg. can tell you all sorts of useful things. but why not make weighing the MH a pre-sales requirement? when we were shopping in 2000 and 2015 for a new coach we insisted on weighing the coach before purchase and by doing so we found two truths:
- don't believe the sales critter or the weight sheet taped to the closet wall unless that weight sheet is specifically for that particular MH and not just the model. be sure to ask if the dealer added anything to the MH after delivery and if the weight sheet in the closet reflects that addition. a call to the MFG with the VIN to verify would be on my list of things to do.
- separate axle weights are the key. it is possible for one axle, usually the rear, to be overweight and yet still show total weight to be less than or equal to the GVWR. we know this from personal experience.
the RV industry, IMO, has done all of us a disservice by creating too many weight ratings. all you really need to know is empty weight per axle (if new, how it came off the factory floor; or if used, what it weighs with no personal items and empty tanks); wet weight per axle (empty other than full fuel, fresh water and LP tanks); axle payload (difference of the GAWR and wet weight on each axle). payload is how much weight owner can add to each axle in food, clothing, supplies, pets, people and other stuff.
does this present challenges for the average buyer? likely, but certified scales are usually not hard to find and wet weights can be calculated using simple math. if you can't find a scale or the seller refuses to let you weigh the coach either find another seller or call the MFG with the VIN and have them certify what the axle weights were when that coach left the factory.
when were shopping in 2015 we made weighing the coach a pre-sales requirement. the seller agreed so we weighed the coach empty and calculated the wet weight. the axle payloads were very good so after the purchase I filled all the tanks and returned to the same scale. my wet weight calculations were slightly different than the actual wet weight but it was a difference without a distinction. we ended up with about 2K pounds on the front axle and 2.4K on the rear axle.
the last step is to verify that your axle weights are equal to or less than the GAWR for each axle once the coach is loaded for travel (including people and pets).
to tow 6000-lbs your coach will need...:
- each axle to weigh less than or equal to its respective GAWR when fully loaded for travel including people and pets;
- to have a hitch rated to tow at least 6000-lbs, usually a Class IV hitch. since you're looking for a DP you may find one that meets this requirement. many, maybe most, motorhomes in the length you're looking may have a Class III hitch (5000-lbs). you may be able to swap out hitches but there may be other modifications you'll need to make. consult a professional frame and chassis expert about this. hint...the RV salesman is likely not a professional frame and chassis expert.
- have a towbar rated to tow at least 6000-lbs
by the way, tow ratings can be misleading. many will refer to the difference between GCWR and GVWR as the tow rating and that may be right..as a minimum. in general, the maximum amount of weight you can safely tow will be the lesser of the following:
- the GCWR (gross combination weight rating) of the MH minus the actual weight of the MH as it is loaded for travel (includes fuel, fresh water, food, clothing, people, pets, supplies, etc.)
- the weight rating of your tow bar
- the weight rating of your hitch
good luck.
38,769 PostsLatest Activity: Apr 04, 2026
