mlts22
Jul 20, 2015Explorer II
Used "C" checklist after purchase?
After buying a used "C" (no final candidates yet as I'm still keeping my eye out), likely on an E-350/E-450 chassis, around 1-5 years old, assuming it was inspected and proven to be in sound mechanical condition and no leaks (especially the cabover area), what would be a good list of items to go over before heading off? Here is what I have. If any of these are not needed, let me know.
1: Change the oil on the Onan generator, replace the carb, since most gensets likely have varnish issues for sitting around too long. It may not hurt to run voltage and other tests on the genset as well.
2: Change the engine oil, oil filter, air filter, brake fluid, brake pads, tires, auto transmission fluid, radiator fluid, and fuel filter.
3: Sanitize the FW tank and plumbing.
4: Replace the anode rod if the water heater is a Suburban, flush it thoroughly if the WH is an Atwood.
5: Pull and replace the fridge if it is a recalled model or year. $1300 for a new DM2652 is a lot cheaper than a burned up rig.
6: Replace the converter with a decent multistage model.
7: Have the mattress and upholstery thoroughly steam cleaned and sterilized.
8: Replace all batteries, both coach and chassis.
9: Rekey all locks.
10: Go over the roof with a fine tooth comb and a roll or two of Eternabond.
Did I miss anything, that might be an issue down the road, assuming a solid chassis/house inspection with no major problems.
9: Rekey all locks.
