pnichols
Aug 01, 2014Explorer II
tatest wrote:
Winnebago names change. For much of the period you are looking at, Winnebago Minnie and Itasca Spirit were "base level" twins (positioned against competitor mid-range models) while Minnie Winnie and Sundancer were the upscale twins,
Thanks much for the Winnebago model summary.
However, I'm not sure I agree on what you said about where Winnebago tried to position Itasca in the market. I considered Itasca (at least up to just few years ago) as upscale from their "Minnie" and "Minnie Winnie" model offerings.
If anyone is interested, take a look at these excerpts from a post I made in another thread where I listed what was included in and on our 2005 Itasca Class C when we bought it new out of the dealer's inventory:
We have a 2005 Itasca Spirit 24V ("324V" - officially) with a Ford V10, but it's on the E450 chassis.
We love our 24 foot Itasca, and it came new with several great features. I'm not sure what of these are standard for that year/model or just what happened to be on it as ordered by the dealer for their lot inventory, or maybe a special order for another customer who never took delivery:
- Automatic electric coach step.
- Aluminum cab running board steps.
- Chrome wheel covers.
- Four unit set of walkie-talkies kept maintained in an automatic charging station.
- Tank heaters for cold weather camping.
- Plumbed for easy winterizing using the built-in water pump.
- Dual coach batteries.
- Exterior entertainment center with outside 120V outlet and 12V receptacle.
- Exterior shower.
- Two exterior storage cabinets run laterally all the way across coach and under it's floor storing long items.
- Weather band radio in the cab.
- Convenient battery disconnect switch right by the coach entry door.
- Dash switch for engine start boosting using the coach batteries.
- Dash switch for running the cab radio from either the engine battery or the coach batteries.
- Automatic charging of the coach batteries by the engine alternator whenever traveling.
- One piece fiberglass roof, deeply crowned, with rolled over edges.
- Full size stock-rimmed spare tire mounted out of the way up underneath, including a large lug wrench for dealing with wheel nuts.
- No slides (which for us was a "feature")
- Exhaust shields underneath the cab flooring.
- Wired internally for satelite systems (but not on the motorhome as delivered).
- Wired for a backup camera (but not on the motorhome as delivered).
- Driver's seat that can be tilted back even though the dinette is right behind it.
- Dual flooring material -> hard surface for the kitchen/rear bed/bath areas, carpets for the dinnette and lounge chair areas.
- Thick cab carpeting with padding under the carpet.
- Digital furnace and air conditioning control.
- Fully ducted air conditioning.
- Fully ducted furnace.
- Cab area and cabover bed privacy curtains.
- Rear corner bed/shower/sink privacy curtain.
- Thick and actually comfortable split cabover mattress.
- Comfortable corner bed mattress.
- Color matched mattress cover for the rear corner bed.
- Double basin kitchen sink.
- Single handle kitchen faucet.
- Built-in water purifier for the kitchen sink faucet.
- Several 120V AC outlets ... some of them GFI protected.
- Several 12V DC receptacles ... one specifically for convenient high current laptop use.
- Fully insulated floors, walls, and ceilings (about 3 inches of insulation in the ceiling areas).
- Gravity locks on all interior drawers.
- Steel slide rails for all interior drawers.
- Piston assisted openers on upward-opening interior cabinet doors.
- Overhead lighting with waist-level wall switches.
- Interior night-light at floor level near the bathroom with waist-level wall switch.
- Fantastic fan roof vent.
- Day/night shades.
- Tank level detectors not inside the tank -> they electronically sense the liquid level right through the tank walls.
- Aluminum and steel wall framing -> not wood.
- Well installed Onan generator that's not too loud or vibration-prone so as to be irritating. It can be run and tolerated for hours if necessary for full air conditioning comfort during warm weather camping.
- The 24V is a basement model, so it's steel walled and fully carpeted exterior storage cabinets are taller and more usable than those of many small Class C motorhomes. This also means that the climb-up height into the cabover bed is not as tall and that you can almost sit up on the cabover bed.
- The rear fender wells are steel lined, so a rear tire blowout may not be as catastrophic as it could be on some motorhomes.
- I'm 6'2" and can stand up in the shower with room to spare.
- The dash radio has two of it's speakers back in the coach for surround sound when camped.
- The dash radio can be controlled from the coach by a remote.
- The dash radio can be controlled by a fob on the steering wheel.
- Both areas under the dinette seats are fully available for storage - no water tanks or furnace cabinets there to take up this space.
- The cab doors have remote locking/unlocking.
- The cabover bed has storage at the head of it and the foot of it.
- The lounge chair slides and pivots.
38,782 PostsLatest Activity: Sep 10, 2026
