woodgeezer
Jun 19, 2014Explorer
You don't say what chassis you have, but I would have the drive shaft professionally checked. I experienced a similar "rattle" on two Fords I owned and had a warn rear u-joint on one and a bad center bearing on the other. Just checking the fit by hand is not the same as doing a fine inspection without load. Cheap check and easy repair.
38,778 PostsLatest Activity: Jun 10, 2026
