greydawg
Aug 16, 2016Explorer
Used PW or LT for rough-road 4-season camping?
Hello all:
I’m looking for a used Class B. The primary use will be for camping – mostly on BLM and National Forest lands, but occasionally in a National Park, State Park or Walmart Park. It will be used as a “tent with metal sides” for the most part – certainly not a luxury travel vehicle.
I don’t particularly want a shower/toilet/blackwater tank (portapotty or cassette toilet are preferable) but it looks like everyone but Sportsmobile takes up valuable B room with a dedicated bathroom. I don’t want (nor can I afford) a Sportsmobile.
I will only consider a Ford or a Chevy gas chassis. No Sprinters and no diesels. No old Dodge gas vans.
I had a 2WD E350 Ford van for several years on which I put 160K miles, and the factory ground clearance was perfect for the sorts of roads I often end up on.
Q1. My inclination is to look for a 2006-2014 PleasureWay or Leisure Travel, as I understand that the RoadTrek drops the floor, significantly decreasing ground clearance. Is this correct?
Q2. Is there any difference in the insulation or 4-season capability between the PW and the LT? Or will I have to winterize pipes in both if camping in sub-freezing temperatures?
Q3. It looks like the skirting on both the PW and the LT lower the effective ground clearance, and my reading leads me to believe the skirting cannot be removed. Is this correct?
I apologize for these questions; if there were any used PW or LT within a couple of hundred miles of me, I’d go make measurements. As it is, it looks like I will need to travel several hundred miles to make a purchase. And it seems these units are scarcer than hen’s teeth!
BTW, my budget is <$50,000 all in, and preferably <$40,000.
Thanks for the help,
GreyDawg
currently camping in the back of a Toyota 4Runner ... a tad snug!
GreyDawg
