RLS7201 wrote:
Maybe I should have been more specific. The 10 gauge, 30 amp cord is not protected properly. If the cord shorts out, then 50 amps can pass through the cord. That is an issue. That is before the RV 30 amp main breaker. Boom, bang, flash, fire!
Richard
The device is limited to 30 amps. And go ahead and short #10 wire into a 50 amp breaker... breaker will trip.
Although you are correct if a high resistance path develops there could be enough amps and heat to cause a fire. However this is also possible on the 30 amp supply so risk is similar.
Same condition exists for a common lamp at home with a 15a outlet and #18 cord.
