Bucky1320's avatar
Bucky1320
Using battery charger in place of converter?
I have a 1990 Gulfstream P30 motorhome. One thing that drives me nuts is battery life. If I leave it unplugged, the batteries go dead quickly, and in days I have dead batteries, which isn't good for them. If I leave it plugged in, the batteries get overcharged, which is also terrible for them.
It has a magnetec converter with charger built in.
In the summer, I often leave it plugged in so that the fridge can run on shore power. During that time, I think that the newer trickle chargers would be much better on the batteries. But how do I go about this? I would love to hard wire it, but with 15A output, I don't know that I could rely on it alone for power when we are using the motorhome. If I plug in the charger with the converter charger enabled, then I suspect the converter charger will continue to overcharge regardless of what the charger is doing.
I don't want to invest in a new converter due to the cost. After all, it is a 1990 motorhome, and I don't want to spend more on this issue than the entire thing is worth. :)
Any suggestions?
  • Hi,
    Add about 60 watts of solar system. Or upgrade the existing converter.
