FIRE_UP
Mar 24, 2015Explorer
murraymcleod wrote:
Looking at that last picture, I see you also have several of the yellow plastic "Lego" platforms. Is there any reason why those shouldn't be used under the jacks, as I have many of those as well?!
murraymcleod,
Well, I purchased those "leggo" blocks quite some time ago and, use them once in a great while. I cracked one, under one of the jacks just after I purchased them due to a tad bit of uneven surface that, that particular jack was on. So, after that, they're primarily used for other purposes. Mainly for my entrance step. I have two different step savers. One is tall and one is short. Which one I use depends on the height of the step, after all leveling operations are complete.
Sometimes, that step ends up fairly high so, I use as many of those "Leggo" blocks as needed to compliment my taller step saver. Other times, the step ends up not too far from the ground so, out comes the shorter step saver. But, anyway, that's what those are primarily used for in my coach.
Scott
