Ev
Feb 11, 2016Explorer
using furnace while driving
My Dash blower stopped working until I can get it looked at can I run the propane furnace for heat while driving to stay warm. Thanks for the input trying to stay warm while heading south.
Old-Biscuit wrote:LongWeekends wrote:wolfe10 wrote:Coyote74 wrote:
Just make sure all is shut down while fueling.
Absolutely correct. ALL sources of ignition should be off:
Absorption refrigerator OFF
Furnace OFF
Water heater OFF
Note: Just having propane turned off at the tank is NOT sufficient.
All those devises have spark ignitors that can trigger whether the propane is on or not. Spark ignitors plus gasoline fumes.....
Slight hi-jack. What?? I see it mentioned nowhere in any of my manuals that I need to take precautions to this level when fueling. Please explain, if you don't mind.
The concern is that just valving propane out at source and not turning the propane fired appliance off the spark electrode/ignitor can continue to spark.
Spark can ignite gas fumes.
That's why I leave my propane fired appliances running..no spartking.
But that's me.
