Dutch_12078
Dec 24, 2017Explorer III
You didn't say which jack system you have, but some let you operate jacks in pairs to prevent twisting the frame. Our current coach has a Bigfoot auto level system, but there is a manual setting that I sometimes use. The way I do it is to run each jack down until they just make ground contact, and then use two buttons at a time to raise each end or side as needed until level. I always use all four jacks for better stability, even if one end or side pair is touching down just solid enough to take some of the weight.
