racnacr's avatar
racnacr
Using RV generator as a backup generator for the house?
So... I live in Pa and our weather here this winter has motivated me to finally do something about using the manual transfer switch that came wired into my house when I bought it. My question for the group is, is my Generac Quietpact 40g capable of 220 output? The biggest problem with using a portable generator during an extended power outage is th 5-8 gallons of gas they hold. You need te refuel several times a day... While my Super C has an 80 gallon tank : ) My transfer switch looks for 220 output to run my well pump. If the RV can't do it, I may upgrade the RV generator, or have the transfer switch rewired to eliminate the well pump and use 110. Am I crazy here, or has anyone else done this? My transfer switch only has 6 circuits, 2 of which are occupied by the well pump. I have meters on the switch so I can monitor, and be sure not to overload the genset. Thanks in advance for any advice!
