RoyB
Feb 16, 2014Explorer II
I do it all the time here at my house on a small scale where I get to store my OFF-ROAD POPUP trailer. I will run a couple of 120VAC extension cords from my off-road POPUP setup into the house to run a few things from the 600WATT PSW INVERTER setup in the trailer.
This is the easy way of doing it and not have to wire anything into the house Power Panel...
We run the home entertainment center, some lights, fans, and chargers for the cell phone and computers. In the winter I have a fireplace to heat the house with but will need 120VAC to run the fireplace internal fan.
When I run my trailer batteries down to around 12.0VDC I will then connect my shore power cable of the trailer directly to my 2KW Honda portable generator and re-charge my trailer batteries in around three hours of generator run time.
During the generator run time I will make my coffee for the day and plug in the fridge to give it a couple hours of running to keep the frozen meat safe.
Using the batteries from the trailer gives us all night to run the few things we have connected and only uses the generator just three hours aday to re-charge the batteries. My generator only has around 7 hours of run time on one tank of gas so this saves us big if we in for a long time without house power. Sometimes finding gasoline in the county is a problem as the local gas stations may be without power as well and can't pump gas...
This is my PLAN B when the power goes out here at our house...
Roy Ken
Roy Ken
38,767 PostsLatest Activity: Jan 13, 2022
