CVD
Dec 04, 2016Explorer
If you have recovery stuff in the Jeep (winch or tow strap), I’d prefer to use that over the tow bar. The receiver is probably the only good “attach point” on the RV, so pulling it backwards should work.
Keep in mind the pressures involved. Moving a 20,000 lb RV when in neutral and on flat, hard ground probably requires only a couple hundred pounds of pressure. Moving that same RV in a “stuck” position (e.g. 18” of mud), requires more pressure than the 4,000 lb Jeep can produce.
38,783 PostsLatest Activity: Sep 09, 2026
