carringb
Oct 15, 2015Explorer
What they all said.... Check the basics first... Air and fuel filters, mouse nest in the intake... Brakes aren't dragging (feel for a hot wheel).... If you can't find anything obvious, it'll probably need to be hooked up to a diagnostics terminal.
Also make sure the proper oil (5w20 or 5W30) was used at the last oil change. Heavier oils can affect cam phaser performance which changes valve timing.
38,763 PostsLatest Activity: Jul 22, 2018
