Captain_Happy's avatar
Oct 15, 2015
V10 not perfoming like it should
I looking for shop to take my 2007 Ford V-10 to in the Las Vegas, NV area to get it diagnost to find why it's not running right. I use to own a 2000 Ford V-10, and this 2007 370+ HP engine is just doesn't have it. The tranny downshifts on the little's hill.
We where on a trip up to Oregon last month and for a few days I was running up medium hills like I was on flat land, and had to back off to keep from running into the person I was following. On the return trip it's right back to the way it's running now. Any help?
  • What they all said.... Check the basics first... Air and fuel filters, mouse nest in the intake... Brakes aren't dragging (feel for a hot wheel).... If you can't find anything obvious, it'll probably need to be hooked up to a diagnostics terminal.
    Also make sure the proper oil (5w20 or 5W30) was used at the last oil change. Heavier oils can affect cam phaser performance which changes valve timing.
38,766 PostsLatest Activity: Jan 10, 2026
