tarnold
Apr 16, 2015Explorer
V10 spins, will not crank...part II
Ok, fixed my self inflicted problem. Yes, it was a pinched fuel hose that I had looked at at leat 4 times. With a fresh start this AM started over checking everything I had done. The Hellwig supplied nut to hold the L bracket is a piece of 9/32 x4x2 threaded steel plate. There are 3(2 metal,1 rubber) fuel hoses, a parking brake cable and 3 wiring harnesses in front of where this "nut" goes running thru the C channel frame. I had pinched the rubber fuel hose when tighten this plate. Will give Ford a nod for their hose choice. Hose poped back into shape when freed from the pinch. Will be watching this area closely for leaks. Put everything back that I had disconnected chasing the problem and took a short 5 mile loop. Thanks for all of the looks and comments.
