IAMICHABOD
Mar 04, 2015Explorer III
OFDPOS wrote:
Thanks for the info, by chance do you recall which valve stems did you get ?
Straight out for inside dualies ? how about the outside dualy and then the fronts ? are your fronts the same as the outer rears ?
The set I got for my RV was the #1-6 FCD
They look like this
http://www.bing.com/images/search?q=tireman+valve+stem+extenders&FORM=HDRSC2#view=detail&id=72C7985E28E590AC6FDD9EABD58C842B4C6D654A&selectedIndex=10
The 2 long ones are for the inside tire and the curved ones are for the outside tire and the short ones are for the front tires. They come with very good instructions,if I remember right Chuck also color coded them so there was no mistake on where they were to go.
If you have any Questions just call Chuck, he is quite a character and will give all the info needed. He also has lists of tire dealers in some areas that know how to install them right.
Oh if you talk to him tell him where you heard about it,he always gets a kick out hearing about "word of mouth" on The Net. He does almost no advertising.
On Edit One more thing they come with Thru the cap type caps so you don't have to remove them to check the air pressure.
